| Version: | CONNECT | ||
| Area: | Installation | ||
| Subarea: | General |
MicroStation was upgraded to 10.17.1.62 and following error is being displayed at startup:
This message is a debugging information and can be closed. MicroStation can then be used normally.
To switch off this error message, please deactivate the following settings under Network and Internet > Proxy:
| Original Author: | Andrea Figurova |
