| Issue Number | Description |
| 757214 | Add Access support to WMTS server with username&Password interactively |
| 776688 | Attaching this xwmts crashes specific MicroStation vvd.xwmts |
| 897094 | Resolved issue with Raster Manager XMWS attachment causes MicroStation to hang with- reprojection - custom CS "S34S' and DKTM3 |
| 803525 | Corrected GCS reprojection from mercator to Lambert not correct for wmts map. |
| 721937 | Fixed opening a certain DGN file that crashes MicroStation. |
| 763736 | Changes to settings like Prefix or Accuracy in Label Coordinates tool not saved after exiting MicroStation |
| 862804 | Fixed issue with print organizer crash when switching view property. |
| 657527 | Resolved issue with Color table wont remain attached and elements get seen in its previous colors after close reopen file. |
| 654713 | Fixed issue with plots with lower WMS raster resolution incongruously take longer to generate and reveal excessive WMS network traffic [LE34 ] |
| 748638 | Improved un-rasterized print in MicroStation takes longer than usual time to to print when WMS is attached to a reference file. |
| 661123 | Fixed Fields are not updating after modifying the shape. |
| 661150 | After Editing Enter-Data Field Text Color Changes to 0, resolved. |
| 658523 | Resolved issue with the status of resizable/sortable columns in list boxes is automatically saved to user preference, the sort marker is showing wrong direction. |
| 656065 | Fixed specific STEP Import is not importing solids at correct location. |
| 654335 | Fixed issue with unable to publish iModel if versioned doc. |
| 660377 | Resolved issue with large databases issues parsing table names using the function mdlDB_describeDatabase() |
| 656991 | Fixed issue where cells in a group deleted in specific file. |
| 657169 | Resolved issue with Level overrides not being saved in specific file. |
| 657222 | Global Display shows Incorrect Used Levels when we have Master & Reference both selected in the Level Display Dialog - Fixed |
| 657248 | Specific file where level displayed in V8i is not retained when opened in CONNECT Edition. |
| 656193 | Linear Pattern not following when placed along curve or arc in specific file. |
| 656118 | Create Region ignores the Max Gap setting when in Flood mode for particular file. |
| 657656 | Fixed issue with Nested reference symbology synchronized itself. |
| 657689 | Links of elements from Reference are still showing visible with the level turned off in certain file. |
| 657626 | Fixed issue with specific file where Global Display level changes of nested reference DWG files are not displayed in Connect Edition after reopening the master file. |
| 661443 | Odd values in transparency and priority slider with decimal delimiter set to comma instead of dot fixed. |
| 753628 | Fixed issue with SmartMatch tool doesn't work for fill type. |
| 670010 | Level name not changing when using smartmatch tool when level filter is on. |
| 790730 | The dialog "LandXML Import" shows blank in the surface field box caused the blank surface name in XML file. |
| 761844 | Resolved issue with SmartMatch matching line style scale and text height and width from a reference file. |
| 761091 | Frozen level information stored in viewport attachment in source model lost while copying model. |
| 875157 | Fixed issue with MicroStation crash when changing level attributes in specific file. |
| 765698 | Fixed issue with crash while using "Update sheet properties" from Sheet Index. |
| 713140 | Black cursor appears invisible in Text Editor Dialog. |
| 658456 | Fixed issue with View Control tool disappears on 4K monitor. |
| 654256 | The Sheet Index does not include the Sheet Model Description - Fixed |
| 653858 | Fixed issue with Chamfer (Method : Distances | Distance/Angle) shows chamfer edit preview handles at opposite sides. |
| 853275 | Extrude along is not working when the Path is longer than 600 meters - Fixed in specific file. |
| 874276 | Fixed issue with problems when create/link variables to Rows and Columns fields in Array feature tool. |
| 780915 | Error dialog displays when changing Boolean variable value of Parametric cell instance in Properties. |
| 659247 | Constraints are lost in generated cell file when creating parametric cell by fence with constraints markers off. |
| 660208 | Fixed issue with loosing constraints in specific file. |
| 867853 | MicroStation crashes when selecting parametric cell to get property information in specific file. |
| 660778 | Position mapping submenu doesn't work with french keyboard - Fixed |
| 762550 | Resolved issue with upgrading products through Connection Client when there is an installation issue in certain conditions. |
| 874542 | Raster (TIF) file did not display when it is not in the same folder as master file for specific file. |
| 835257 | DWG text node frame/background mask is not displayed correctly as AutoCAD does in specific file. |
| 892472 | Fixed issue with Line style of mesh elements in DWG file revert to "0". |
| 660468 | Text Style Name Template doesn't work when Saving DGN as DWG in specific case. |
| 660346 | DWG text node frame/background mask is not displayed in MicroStation in certain file. |
| 657333 | Cells missing when saving DGN to DWG and merging References in specific file. |
| 657349 | Resolved issue where PLine linetype did not show on AECC_TIN_SURFACE when LT generation is disabled. |
| 657379 | Incorrect display of AutoPLANT DWG files in hidden lines display, resolved in specific file. |
| 656132 | Converting DGN to DWG files will cause a crash of program due to lack of memory fixed. |
| 653555 | Fixed issue with new Notes placed in attached Dwg file, get distorted when reference in another dwg file. |
| 654768 | Resolved issue where Multiline Text & Text Frame of DWG have different results in AutoCAD and MicroStation in specific file set. |
| 654940 | Resolved issue where, DWG drawings generated with Civil 3D displays in sheet model different than in AUTOCAD. Labels (Text) are Not Rotated. |
| 653689 | Fixed issue where converting this specific file to DWG, the text of the dimensions shift upwards. |
| 689372 | Fixed issue with specific file where eport to DWG creates empty ref. file. |
| 735863 | Fixed issue in specific file where Line style of line string elements in DWG file revert to "0". |
| 721478 | Specific DWG file not displaying custom line styles correctly. |
| 721489 | Specific DWG file not displaying Label group scale correctly in sheet models. |
| 794928 | AECC_STATION_OFFSET_LABEL flipped over in specific file. |
| 725907 | Reference file geometries not reprojected correctly after keyin "reference reload force all" for certain file. |
| 657424 | Reference->Presentation-> display style, not getting applied for the specific reference file. |
| 657455 | Fixed issue with Models Dialog ' Description' column does not sort in alphabetical order correctly. |
| 657654 | Resolved issue with MS_REF_MASTERFILELAST_DESIGN Configuration Value setting. |
| 655132 | Elements get selected which are outside clipped referenced boundary in specific file. |
| 845238 | Shape file GCS not loaded correctly in specific file. |
| 786189 | Resolved issue where ‘Label line’ tool not showing bearing direction correctly on reference elements. |
| 802391 | Fixed issue with Google Earth Synchronization tool displaying error message of incorrect version. |
| 768024 | Fixed issue where, Place Circle> tool-setting> changing options from Diameter> Radius> Diameter would cause a crash. |
| 767614 | Resolved issue where Element Selection By Type unselected elements by all Types, not one type. |
| 764673 | Fixed issue with Place Circle> tool-setting> changing options from Diameter> Radius> Diameter cause crash in specific file. |
| 776541 | Editing Chinese tag brings error display for specific file. |
| 654996 | Fixed issue with the Construct Active Point Along Element tool does not allow you to pick an element below an existing Point element in which to place new Point. |
| 655667 | Resolved issue with Graphic Groups element loses its association to the group when modified. |
| 653521 | Block attributes in DWG file are not automatically displayed when opening in MicroStation and viewing as tags. |
| 653561 | Fixed issue with ghost image of dimensions are seen on the left-bottom corner of the drawing. |
| 653600 | After editing dimension text, text weight changes to 0 weight cannot change text weight after that. Dimension line and extension lines change in specific file. |
| 653605 | Dimension Style Extension Lines do not display correctly in specific file. |
| 653615 | Label Line tool dimensions wrong angle for reference attached to sheet model for certain file. |
| 653645 | Fixed issue with Text Style used in dimension style is not shown in Text Editor while editing dimension text. |
| 659390 | Fixed issue with the call the “placelabel associationstate” on or off from a macro nothing changes on the dialog. |
| 658570 | Key-in “placelabel associationstate off” does not display ‘Place Label’ tool-setting> ‘Association’ button as Off. |
| 658571 | Key-in “placelabel relativeassociationstate On/Off” does not display ‘Place Label’ tool-setting> ‘Relative Association’ button as On/Off. |
| 660243 | Fixed issue where insertion point difference when using Insert Vertex on a Curve. |
| 653589 | Using "placelabel dialog" via VBA does not support associative points - Resolved. |
| 654572 | Resolved issue where unable to export instances of item if attached to model. |
| 678865 | Report not selecting cell element in the dgn, When the selection type is “Current Selection” |
| 764575 | Item Type Origin value incorrect for specifi file. |
| 657562 | Fixed issue with Reference presentation is overriden by Display style of view. |
| 657671 | The Key-in “rotate view element;%d;point ab;reset” does NOT rotate the view until the element is horizontal but it rotates to the nearest 90 degrees. |
| 658272 | When a terrain has triangulation turned on and thematic height display is applied, then each triangle displays thematic height. |
| 816367 | Fixed issue with specific file where file will crash when changing display style to Illustration. |
| 770212 | Fixed issue with OBJ file is opened or attach as reference causes crash. |
| 660300 | Extend to Intersection on Line Strings fixed. |
| 660303 | Fixed issue where Break Element does not start Accudraw. |
| 656376 | Fixed issue with Construct Circular Fillet Tool does not work correctly when launched from Modify Tools Toolbox. |
| 655258 | Resolved VBA does not work with MSbatch ( cmd line Batch Process ). |
| 734822 | Fence File Copy filled shapes clipped in Sheet Model Levels change to 'Default' in copied output file. |
| 734807 | Fence File Copy filled shapes clipped in Sheet Model not in copied output file |
| 687356 | Resolved support for SketchUp group elements. |
| 709777 | Import STEP file (.stp) is not complete in specific file. |
| 822905 | Fixed issue with a crash when editing a specific file with Copy Parallel tool. |
| 760096 | Resolved a crash when calling DgnPlatform GetComponentId. |
| 790114 | Fixed issue with Conflicting _VARNAME is defined. |
| 724438 | Dot net framework error when clicking on Render Scene is resolved. |
| 703818 | Fixed issue with Cloud layers not working in Copied Atmosphere preset. |
| 669288 | Resolved VUE Rendering with Path Tracing option, produces black output. |
| 763486 | Fixed issue with VUE does not render lines in specific file. |
| 763944 | VUE Render Output Channels Not Working Correctly for indoor scene for specific file. |
| 785341 | Resolved issue with renders with set Atmosphere to None doesn't save alpha channel |
| 867467 | Fixed issue with Nvidia denoiser not working with R7. |
| 802711 | Updated Reference Files not Rendered in Vue at Updated Location. |
| 779749 | Fixed issue with ECX ITEMS DUMP crashes MicroStation for specific file. |
| 656075 | Microstation Update 13.1 does not shows the IFC attributes properties for attached IFC file. |
| 656057 | Fixed issue with IFC PSet_* propeties are not seen in element info dialog on selecting element. |
| 670475 | Reoslved issue with Named Group element information shows all elements of Named Group as duplicated properties. |
| 701857 | Attach item types to selection doesn't work in dgn when item types are defined in dgnlib in specific case. |
| 716685 | Change reference file orientation in specific file results in Model Not Found error. |
| 727314 | The filtering options from the "Preview Results" are not displayed in the correct unit. |
| 812832 | Fixed issues with opening Clash Detection dialog causes crash with specific DGN files. |
| 876937 | Reference attachment method variable is not working in specific file. |
| 908697 | Fixed issue with hovering over attached IFC items crashes MicroStation. |
| 743078 | Resolved issue with attaching Reality Mesh using URL crash MicroStation. |
| 748890 | Mesh subtract tool crashes while generating output in specific file. |
| 760016 | Fixed issue for File Compress, it should show a message that File Compress is recommended at the end of the session. |
| 776912 | Fixed issue with specific file crash upon opening. |
| 805127 | Fixed issue with reality mesh with incorrect format should not be attached. |
