| Version | PLAXIS 2D PLAXIS 3D 2016 |
| Date created | 22 January 2013 |
| Date modified | 22 January 2013 |
This document describes an example that has been used to verify the unsaturated flow capabilities of PLAXIS. The problem involves the steady-state solution of the suction head for the case of uniform constant evaporation in unsaturated media.
Used version:
This requires a PlaxFlow module for transient groundwater flow
