| Version | PLAXIS 2D 2015 PLAXIS 3D 2012 |
| Date created | 16 August 2013 |
| Date modified | 16 August 2013 |
Normally, the Output program is needed to select specific nodes and stress points for which data will be stored during the calculation. This data can be used to generate curves. Alternatively, it is also possible to select points for curves prior to the calculation by using the command line in PLAXIS 2D Input and PLAXIS 3D Input. This can be useful when using commands in the commands runner for example.
Since PLAXIS 2D 2017 and PLAXIS 3D 2017, this command option is available:
Note: the command __selectcurvepoints is no longer available since PLAXIS 2D 2017 and PLAXIS 3D 2017
In order to control Plaxis Output through commands, first Output needs to be launched properly by first using the command selectmeshpoints from Input. Then, you can call any Output command from Input by prefixing the command with /output. Input will then know that this command should be senτ to Output in order to execute it. We can use the addcurvepoint command to select nodes and stresspoints and finally, we need to store the selected nodes and stress points using /output update.
To select points for curves prior to calculation, the commands in Input would look like this:
selectmeshpoints /output addcurvepoint "Node" (x y z) /output addcurvepoint "StressPoint" (x y z) /output update
Note, the parentheses on the coordinates in the command are not necessary but help to read the line.
To select just one coordinate in PLAXIS 2D
selectmeshpoints /output addcurvepoint "Node" (5 0) /output update
This will select a node nearest to coordinates (x, y) = (5 ,0)
To select just one coordinate in PLAXIS 3D
selectmeshpoints /output addcurvepoint "StressPoint" (0 3 5) /output update
This will result in selecting a stress point nearest to (x , y, z) = (0, 3, 5)
To select multiple coordinates in PLAXIS 2D
selectmeshpoints /output addcurvepoint "Node" (0 1) /output addcurvepoint "Node" (10 1) /output addcurvepoint "Node" (0 -10) /output addcurvepoint "Node" (10 -10) /output addcurvepoint "stresspoint" (0 1) /output addcurvepoint "stresspoint" (5 1) /output addcurvepoint "stresspoint" (0 -10) /output addcurvepoint "stresspoint" (5 -10) /output update
This will result in:
See also the Command Reference via the Help menu for more details and options.
Note this command is not supported anymore since PLAXIS 2D 2017 and PLAXIS 3D 2017.
This command used to do the following:
For more details, notes and some examples, see the attached PDF file: PLAXIS2016_Select_points_curves_prior_calculation_directly_in_Input.pdf
