Product(s): | MicroStation | ||
Version(s): | 10.17.01.62 | ||
Environment: | N\A | ||
Area: | Configuration | ||
Subarea: | Workspaces |
Open DGN file in a specific WorkSpace, WorkSet
We want to open a DGN (by double click) in a specific WorkSpace, WorkSet
Set the following configuration variables
_USTN_WORKSPACENAME = MyWorkSpace
%lock _USTN_WORKSPACENAME
_USTN_WORKSETNAME = MyWorkSet
%lock _USTN_WORKSETNAME
The above configuration variables can be added to Personal.UCF
%localappdata%\Bentley\MicroStation\10.0.0\prefs\Personal.UCF
To set the above configuration variables, at Application level, create a CFG file e.g., MyConfig.CFG and copy the file to the following location
C:\Program Files\Bentley\MicroStation CONNECT Edition\MicroStation\config\appl\
Getting Your First WorkSpace and Workset Setup
Original Author: | Leonard Jones |
