| Version(s): | 10.15.00.74 | ||
| Area: | Raster | ||
| Subarea: | N\A |
Capture key-in missing in CONNECT
From User...
In v8i you could take screenshots and other stuff via the keyin "capture view". The entire "capture" keyin is missing in CONNECT!
Go to "Drawing > Utilities > Image > Capture" which loads the MDL "SCRNCAPT". Once the MDL is loaded the Capture key-ins are available
Alternatively key-in “MDL LOAD SCRNCAPT" and the Capture key-ins are available in CONNECT
To load this MDL automatically in all MicroStation sessions
• Open any text editor "notepad" and "Run as Administrator"
• Open the following CFG file
C:\Program Files\Bentley\MicroStation CONNECT Edition\MicroStation\config\system\applicationload.cfg
• Look for the configuration variable "_USTN_FIRSTDGNFILE"
• Go to the last occurrence of this variable
• Add "_USTN_FIRSTDGNFILE > scrncapt"
| Original Author: | Leonard Jones |
