| Version: | CONNECT | ||
| Area: | Point Cloud | ||
| Subarea: | N\A |
How to import / attach Laz/.las file to MicroStation CONNECT Edition.
You can open a Point Clouds tool > Attach and you can choose .las file format. As we can read in MciroStation HELP:
“Only POD files can be attached to a design file. For all other supported file formats, such as LAS, the Convert dialog opens. This dialog allows you to choose the desired conversion options and to save the selected point cloud file as a POD file.”
| Original Author: |
Klaudia Piekielniak |
