| Version | PLAXIS 2D 2017 PLAXIS 3D |
| Date created | 04 July 2017 |
| Date modified | 04 July 2017 |
When modelling semi-permeable or impermeable structures like retaining walls or tunnel linings, the permeability of such a structure is not controlled by the structure itself, but by the interfaces surrounding it. These interfaces, when active in flow, can be defined as fully permeable, impermeable, or semi-permeable. This article shows situations and considerations when modelling semi-permeable structures like retaining walls or tunnels using semi-permeable interfaces.
In practical cases, one often has interface elements at both sides of a wall: for example, in the case of an excavation where the wall is, to some extent, permeable. When using the semi-permeable interfaces at both sides of the retaining wall, the hydraulic resistance for both interfaces will be taken into account (i.e. summed).
In such a case it is suggested to:
This will ensure that the retaining structure's hydraulic resistance will not change during (multiple) excavation stages.
This can be done in two ways: a specific material dataset or deactivating the interface for flow.
One way to set this "inside" interface to fully permeable is by defining a specific material dataset and setting the Cross permeability of the interface to Fully permeable:
Figure 1. Setting Cross permeability to Fully permeable
To create this specific dataset:
This implies you need to create a specific material dataset for each soil material in which the plate is embedded.
When an interface is set to inactive for flow, it will act as if it is not there, and water can flow across this inactive interface without any resistance. Instead of setting a specific material dataset to the "inside" interface, we can now set the inside "Active in flow" state to inactive (uncheck the checkbox), while we keep the "outside" interface "Active in flow" checked.
Note that this setting is independent of the general active state for interfaces which are used for the deformation analysis:
Figure 2. PositiveInterface_1_1 set to Inactive for flow to behave as fully permeable while the interface state for deformation is set to Active.
We can also easily inspect this configuration visually: when we are in Flow conditions mode, we see the interfaces (Figure 3):
Figure 3. Outside interface (in this case Negative interface) set to active in flow,
and is drawn in orange and inside interface (in this case Positive interface) set to
inactive and is drawn in grey
This setting should then be explicitly checked for your phases.
Similarly for a semi-permeable tunnel lining: the correct interface permeability should be given to the interface on the outside of the tunnel lining, whereas the interface at the inside (which will be excavated) should be modelled as fully permeable.
Both approaches mentioned above can be applied here, too.
