PLAXIS Bulletin publications
This section contains several articles that appeared in the PLAXIS Bulletin: A bi-yearly magazine published by Plaxis bv from October 1996 to Spring 2017.
2D FEM analysis compared with the in-situ deformation measurements - Martin A. op de Kelder
2D Thermal analysis of soil freezing with flowing water - J. Sopko
3D Finite Element Analyses – Interaction between Abutment and Adjacent Earth Embankment of a Modern Railway Bridge - T. Meier, S. Rosner, T. Sembdner, P. von Wolffersdorff
3D Finite Element Analysis of a Complex Excavation - Z.Y. Orazalin, A. J. Whittle
3D Modelling of Train Induced Moving Loads on an Embankment - M. Shahraki, M.R.S. Sadaghiani, K.J. Witt, T. Meier
Back analysis of settlements beneath the foundation of a sugar silo by 3D finite element method - B. Móczár, A. Mahler, K. Lődör, Z. Bán
Comparison of Structural Elements Response in PLAXIS 3D and SAP2000 - C.G. Gragnano, V. Fargnoli, D. Boldini, A. Amorosi
Comparison of the effectiveness of Deep Soil Mix columns using 2D and 3D Plaxis - H. Leung, S. Terzaghi
Evaluation of the up and down movements of the Vlaketunnel with cyclic analysis using PLAXIS 2D - N. Benhaddou, K.J. Bakker
Geomechanical modelling of the Dutch radioactive waste disposal facility accounting for uncertainties - P. J. Vardon, P. Arnold, M.A. Hicks, P.A. Fokker
Modeling passive earth pressures on bridge abutments for nonlinear Seismic Soil - Structure interaction using Plaxis - A. Shamsabadi, S. Nordal
Pavement service life prediction and inverse analysis with PLAXIS 3D - C. Rabaiotti
PLAXIS 2D and 3D applications in geotechnical earthquake engineering - A. Laera
PLAXIS 3D Analysis of the Groninger Forum - M.C.W. Kimenai
Preliminary 3D Modelling of Structural behaviour of Face Bolting and Umbrella Arch in Tunneling - A. Monnet, E. Jahangir
Reliability of Quay Walls Using Finite Element Analysis - H.J. Wolters, K.J. Bakker, J.G. de Gijt
Validating a new design method for piled embankments with PLAXIS 2D and 3D - T.C. van der Peet, P. G. van Duijnen, S.J.M. van Eekelen
Validation and Application of the Embedded Pile Row Feature in PLAXIS 2D - J. Sluis, F. Besseling, P. Stuurwold, A. Lengkeek
See also
Publications Overview - PLAXIS    [Publications]
Tutorials PLAXIS 2D    [Tutorials]
Tutorials PLAXIS 3D    [Tutorials]
Verifications - PLAXIS    [Verifications]
Practical Examples - PLAXIS    [Examples]
