| | Product: | MicroStation | |
| | Version: | V8, 2004, XM, V8i, CONNECT | |
| | Environment: | N\A | |
| | Area: | Levels | |
| | Subarea: | Level Display | |
How to turn a level off with the Off By Element method in V8 versions of MicroStation?
- Open the Level Display dialog
- Right click over a Level and choose Off By Element. Then identify the element you wish to hide in the view with a left-click.
- Alternatively, use key-in levelmanager level offbyelem and then select an element in the view where you require this level turned off
Turn off levels by simply selecting an element
Other language sources
| | Original Author: | Bentley Technical Support Group | |
