| Issue | Description |
| 1045180 | Fixed crash while opening specific DWG file. |
| 1046890 | Resolved crash with Item Type Filtered Picklist when used in Arrays with specific file |
| 1052875 | Resolved issue with controls from the Modify Named Presentation Dialog Box in localized environment |
| 994453 | MicroStation crashes when placing a tag set with Association disabled in the Attach Tags dialog |
| 997228 | Fixed issue with importing Level Table from corrupted dng file that causes a crashe |
| 999526 | Fixed issue when toggling Reference dialog column cannot be toggled on/off for 2D referenced files. |
| 1003843 | The element with anchored fixed constraint is moved in non-top/bottom view. |
| 1021199 | Linestyle symbology not showing on existing linestyles, show as "Not Found" in specific rsc file |
| 1024573 | Modify Solid Entity Tool fails when issuing Tentative Snap on Snap Point with Face Mode activated |
| 1026274 | Resolved issue with WinHttpGetProxyForUrl error: ERROR_WINHTTP_UNABLE_TO_DOWN LOAD_SCRIPT at startup |
| 1027892 | Fixed crash while attaching attached specific TIFF file |
| 1028193 | Resolved issue with specific case Associative Extraction - Edge |
| 1028255 | Fixed issue where MS_CONFIGURATIONOPTS is ignored when set at Organizational Level |
| 1031527 | Resolved crash with Place Label tool-setting> click on ‘Filter Cell Names’ button with large cell list causing a crash |
| 1031588 | WMS raster attachment not displayed correctly after selecting new coordinate system |
| 1033182 | Resolved crash when trying to Toggle Auto 2D Constrain Settings while Profile is selected |
| 1037557 | Fixed issue with specific WMTS raster image is not coming in when it is nested attached in another model and the orientation is Geographic - Reprojected |
| 1037870 | Resolved issue with Exception occurred while iterating ItemType by using C++ |
| 1039095 | Fixed issue with required Config variable which will override the preferences MS_VUE_HISTORY |
| 1039332 | Resolved crash when Place Table from specific Excel File in any DGN file |
| 1040717 | Performance issue when updating Item Types from DGNLIB file |
| 656042 | After converting DWG to DGN and running the key in: convert acistoparasolid all, using display view smooth part of the aircraft becomes transparent |
| 861140 | Resolved issue with Annotative AEC_MVBLOCK_REF objects from Xref. displayed in wrong scales. |
| 873108 | Display of nested reference gets turned off in a sheet model after turning on and off another reference in a design model |
| 906169 | Fixed issue with specific field values changed from dgn to dwg when opened in AutoCAD. |
| 908986 | Resolved issue where Loft Solid Tool does not consider Grouped Hole as a Profile Element |
| 982037 | Fixed issue with branding DGN should also show Configuration name along with WorkSpace and WorkSet. |
| 983032 | Profile based solids created using 2D Parametric Cell having Placement Points adopts Property of a Placement Points |
| 983109 | Profile based solids created using 2D Parametric Cell having ByLevel Properties Property are not consumed correctly (Attributes appear as 0,0,0) |
| 988367 | Item type Text Fields placed from cell file are not updating when property pane is closed. |
| 989847 | Resolved issue with specific PDF file crash while open, import or attached PDF file as Vector PDF. |
| 992606 | Branded file does not to switch to correct workspace/workset, when Custom/Example Configuration is activated and opening DGN (using double click) from Manage Configuration |
| 670280 | Fixed issue with MS_KMLOUT variable not honored when using Export Google Earth File tool |
| 697570 | Fixed issue with Point Elements From geo connector is not getting selected when we attach iModel created from Geo Connector |
| 728258 | Resolved issue with Cut Solid Tool - preview does not update when hitting the Shift key as per message |
| 728262 | Fixed issue with Cut Solid Tool - cut with line is not orthogonal as selected and shown in preview |
| 728719 | Fixed issue with Perforator failed to work after changing Active Angle value while placing specific Parametric cell |
| 768377 | Fixed issue with MicroStation crashes when changing property on specific reference files |
| 656804 | Resolved issue with Save Multiple Image tool uses only one machine for rendering when using Distributed Rendering |
| 660557 | Fixed issue with Word Wrap of Text Nodes from DWG Files |
| 661140 | Resolved issue with Enter Data Fields not working when user uses EDF character in text editor dialog |
| 661602 | Fixed issue with VBA methods to create new elements from given array of elements like CreateCellElement1 are raising a runtime error or crash if executed from external process |
| 653763 | Fixed issue with Perforator : If Assembly Solid having Perforation is moved by distance x then Placed perforator cell is moved by distance 2x |
| 653934 | Resolved issue with Cut Solid with Curve (Cut Method : Split Solid) : Tool does not give correct result when we use multiple Line elements as Cutting Profile |
| 654974 | Instances of Array Along Path Feature appear distorted when we 'Show Input Element', Transformation is restored back to normal moment after you 'Hide Input Element' |
| 655230 | Improved performace with Non-displayed Nested References are loaded when we open the file - which causes Performance issues when opening files |
| 945612 | Fixed issue with DWG drawing generated with Civil 3D displays in sheet model different than in AutoCAD, MicroStation text is spread over two lines in AutoCAD a single line. |
| 945809 | Resolved issue with exporting Sheet Model only gives incorrect results. |
| 946864 | Fixed issue with VBA File properties documentation: Update Design File Property Descriptions (typical) wrt Runtime error and Values returned |
| 949591 | Resolved issue with unloaded PDF displays in MicroStation |
| 959061 | Fixed issue with incorrect annotation scale for "AECC_ALIGNMENT_STATION_LABEL_GROUP" text in cell in paper space for specific file |
| 961947 | Added the ability to remove/hide the Configuration from start Screen. |
| 961950 | Addedthe ability to remove/hide Manage Configuration from start Screen. |
| 963911 | Upgraded libxml2 with known CVE |
| 964934 | Fixed issue with SmartMatch tool matches Fill Type for linear elements |
| 968458 | Resolved issue where you cannot change custom line style scale first time in specific file |
| 970293 | Resolved issue with "AECC_ALIGNMENT_STATION_LABEL_GROUP" text in cell in paper space text displays at incorrect angle in sheet model |
| 971302 | Fixed issue where you are not able to Append Parametric Cell (having a certain combination of Parametric Solids in the Cell Definition) with the Features (e.g. Hole) |
| 980896 | Fixed issue were Report result is not matching with result shown in Explore window in specific file |
