Product: | MicroStation | ||
Version: | V8i, CONNECT | ||
Environment: | N\A | ||
Area: | Programming | ||
Subarea: | VBA |
How do I use a macro that I was sent?
How do I integrate a sent file "Example.mvba" into MicroStation?
1. Save the file
2. Open the Utilities > Macro > Project Manager
3. Load Project - Navigate to your saved file "Example.mvba" - Open. The macro is then loaded and ready for use.
4. Select the macro you would like to run
5. Hit the big "Play" icon in the Project Manager to access the loaded macros.
6. Select the macro you would like to run
7. Hit the run button to run the macro.
Original Author: | Tristan Anderson |
