| Version: | CONNECT | ||
| Area: | Documentation & Help | ||
| Subarea: | N\A |
Where can I find a listing of all key-ins in MicroStation CONNECT Edition?
All MicroStation key-ins are available under the tab "Key-in Index" in MicroStation CONNECT Edition Help Contents.
By default, the Help Contents will be opened online.
You can uncheck the Online Help setting to view it offline.
1. Navigate to File > Settings > User > Preferences > Help Settings > Turn off the "Use Online Help" setting. Click OK and go back to main interface. Save Settings (CTRL+f).
2. Now go to File > Help > Help Contents. In the tab options in the bottom left, click on "Key-in Index".
How to find listing of all key ins
Creating tool icons
| Original Author: | Judy Wong |
