| Application | 2D SVSLOPEĀ |
| Version | 2D SVSLOPE |
The following example will introduce some of the features included in SVSLOPE. This tutorial shows an embankment with a roadway along the top of the embankment. The slope downstream slope stability was analyzed with no supports, and with the addition of anchors. The purpose of this model is to determine the effects of supports on the resulting Factor of Safety. The model dimensions and material properties are described in the download files below.
Downloads
