| | Product(s): | MicroStation | |
| | Version(s): | CONNECT | |
| | Environment: | N\A | |
| | Area: | UI Customization | |
| | Subarea: | Function Keys | |
I am using a customized function key menu ‘xxkey.mnu’ It works fine once I have attached the file however each time I re-start Microstation it does not load the function key menu.
Add the file "xxkey.mnu" to the prefs folder and point to it to Configuration Variable (MS_FKEYMNU) to : C:\Users\your.name\AppData\Local\Bentley\MicroStation\10.0.0\prefs
Other Language Sources
Deutsch
Spanish
Italian
| | Original Author: | Judy Wong, Bentley Technical Support Group | |
