| Version: | CONNECT | ||
| Area: | Base Geometry | ||
| Subarea: | N\A |
Key-in to change Arc Angle in Cloud tool.
From User…
How can I set default revision cloud settings.
There is no key-in to set Arc Angle, Radius. However, you can record a Macro, set the required parameters and save it as a VBA.
Check this Wiki for Macro recording.
Here is a sample recorded VBA that has been edited to place clouds with Angles 100, 120.
Sub CloudAng100()
' Send a keyin that can be a command string
CadInputQueue.SendKeyin "place revcloud points"
' Set a variable associated with a dialog box
SetCExpressionValue "cloudParams.radius", (ActiveModelReference.UORsPerMasterUnit * 0), "CURVE"
SetCExpressionValue "cloudParams.sweepAngle", 100, "CURVE"
End Sub
Sub CloudAng120()
SetCExpressionValue "cloudParams.sweepAngle", 120, "CURVE"
End Sub
Check this Wiki for executing VBAs via key-ins.
Following are sample Key-ins to Load and Execute VBAs.
macro vba load TestCloud; macro vba execute CloudAng100
macro vba load TestCloud; macro vba execute CloudAng120
VBA attached for reference.
communities.bentley.com/.../TestCloud.mvba
| Original Author: | Leonard Jones |
