| Version: | V8i, CONNECT | ||
| Area: | Drawing Aids | ||
| Subarea: | AccuDraw |
Accudraw shortcuts are not responding.
The accudraw command indicator pops up, but nothing changes.
Returning message "Unknown key-in or command"
Numerical commands are not populating fields.
1. Accudraw is not started.
Symptoms: No compass in view.
Solution - Enable Accudraw.
2. Not focused on Accudraw dialog
Symptoms: Shortcut popup message does not appear.
Solution - Click the Accudraw dialog to focus on it.
3. Keyboard Number lock is not on (when entering numeric values)
Symptoms: Entering values in accudraw fields does not work.
Solution - Press NumLock on keyboard.
4. Missing shortcut command from shortcut file.
Symptoms: No command results and no popup messages.
Solution - Press SHIFT+/ (?) to get the shortcut list. Add the needed
command to the list.
Optional: key-in: ACCUDRAW SHORTCUTS DEFAULT (Resets shortcuts to
delivered settings)
