| Product(s): | MicroStation | |
| Version(s): | V8i, Connect Edition | |
| Environment: | N\A | |
| Area: | Cells | |
| Subarea: | Annotation Cells | |
Problem Description
When I place a Cell into a file that has Annotation turned on in the cell library MicroStation places it into the file with the "Is Annotation" flag set to FALSE. I need to change this status to TRUE but it is greyed out.
Steps to Resolve
- Open the cell library and right click on the cell you need to be set "true" and choose "Open for editing"
- In the *.cel file, open the model in which there is your cell, right click and choose properties
- In Cell Properties, tick the box: "Can be placed as an annotation cell"
- Click ok and save the file
- Re-open the dgn in which you were working and try again to attach the cell
- Opening the cell library, see that the annotation cell symbol is available: attach the cell and remember to check the box: Scale Annotation and Annotation (if applicable)
Please have a look at the video below:
See also
What are Annotation Cells
Active Scale is ignored when placing Cell
Other language sources
| | Original Author: | Mara Manconi | |
