1D Road Pavement
Application
2D SVENVIRO
Version
2D SVENVIRO
The damage due to the frost leave on Canadian roads amounts to significant cost each year. One of the critical aspects when analyzing frost heave is determining the depth to which the freezing front extends beneath a road surface. This tutorial illustrates the use of SVHEAT SVENVIRO to calculate the depth of frost penetration using actual climate data and analyzing the scenario over the course of a single year.
The purpose of this tutorial is to illustrate:
·Procedures to create a 1D SVHEAT SVENVIRO model
·Using different methods to specify thermal material properties
·Applying the temperature as the climate boundary condition
·Solve a transient problem of heat transfer
·Determine the depth of penetration
Downloads
[Tutorials]
