| Version: | CONNECT | ||
| Area: | Configuration | ||
| Subarea: | User Preferences |
How to enable Position Mapping shortcuts and make them visible in MicroStation CONNECT Edition?
Here is Position Mapping enabled along the Ribbon:
***NOTE*** - Many users opt to use Position Mapping in combination with the Dialog v8i Mode as this was a common workflow in the earlier v8i versions.
Note that this feature is also available in PowerDraft CONNECT Edition - it was not present in earlier PowerDraft versions.
CONNECT Edition - Using Position Mapping to get to Tools Really Quickly! - Blog
Position mapping is not working
| Original Author: | Anu Kuusiaho |
