| | Product: | MicroStation | |
| | Version: | V8i, CONNECT | |
| | Environment: | N\A | |
| | Area: | View | |
| | Subarea: | Saved Views | |
How to Update a Saved View.
The development of a project may require an update of Saved Views to better meet the Customer needs.
Option 1:
- Open the Explorer menu by selecting the Explorer command.
- Expand the Saved Views drop-down tab and, by right-clicking on the list of views, select the Update.
- From the Update Saved View Setting menu, select the View that need to be updated
- Focus the screen view at the desired position and left click on it.
Option 2:
- Open the Saved Views menu menu from the View tab
- Select the View that need to be updated and press Update Saved View setting command
Video
Saved Views - View - MicroStation
Other language sources
| | Original Author: | Bentley Technical Support Group | |
