| Application | PLAXIS 2D |
| Version | PLAXIS 2D |
| Date created | 30 May 2011 |
| Date modified | 29 March 2020 |
PLAXIS 2D and PLAXIS 3D
To reset the language in PLAXIS 2D and PLAXIS 3D follow these steps:
- Start the Input program;
- Wait for the general start-up form
- Now press CTRL+ALT+SHIFT+R: a message appears that the language will be reset
- After a restart, you may choose a new language to use.
Legacy: PLAXIS 2D Version 9
To reset the language in PLAXIS 2D Version 9
- Create a new project (which will be topmost radio button) and click OK (leftmost button at the bottom of the window)
- Accept the general settings by clicking OK (middle button at the bottom of the window)
