| Version: | CONNECT | ||
| Area: | Solids | ||
| Subarea: | General |
How to remove editing functions applied to the solid 3D objects?
Use the Delete Feature command form the object Properties window.
Select the object where you need to delete the applied Modify Command and open the Properties Menu.
In the following case, the Boolean Tools Union was applied
Right click on the applied modify command > Delete > Feature
Other Language Sources
