| Version: | V8i, CONNECT | ||
| Area: | Base Geometry | ||
| Subarea: | N\A |
How can you place a closed Bspline curve with a fill?
1. Make sure 'Fill' is on in View Attributes
2. Go to Utilities>Keyin type "change fill" this will bring up the Change Element Fill tool settings
3. Change Fill type from 'None' which is default to 'Opaque', this turn on fill setting for all close shapes
4. Place bspline curve with 'Closure' set to 'Closed', closed bspline curve will be filled
Bspline curves must be closed in order to be filled.
Other Language Sources
| Original Author: | Reginald Wallace |
