Hidden Lines not printing correctly
 Product:MicroStation
 Version:CONNECT v10.16.02.34
 Environment:Windows 10
 Area:Printing
 Subarea:Dialog
When printing my drawings that contain references with hidden lines, some of the hidden lines are not displaying correctly in the print output.
This only occurs on some files, and others print just fine.
If some or all of the files in the problematic data set are 3D, then try exporting to 2D.
This is known to resolve some issues with printing problems related to hidden lines.
Another solution would be to print with "Rasterized" toggled ON
Other language sources
Deutsch
 Original Author:Jayson Perry
