| Version(s): | 08.11.07.446 | ||
| Area: | Printing | ||
| Subarea: | Dialog | ||
| Original Author: | Marco Salino, Bentley Technical Support Group | ||
Clipped Reference is Printed Out Incorrectly.
A clipped reference is printed out with continuous lines - not visible on the screen - where the boundaries of the clipping element (a fence in this case) were placed.
Check if the affected reference was placed using the "copy reference" command instead of being attached as an individual reference using the "attach reference" command.
In some cases detaching the "copied instance" of the reference and attaching it as a proper individual reference file can resolve the issue.
