| Version(s): | V8, XM, V8i | ||
| Area: | Settings/Attributes | ||
| Subarea: | N\A | ||
How to change multiple elements from being locked to unlocked.
1. Select the elements using the Element Selection tool.
2. Unlock these element under the menu > Edit > Unlock.
Other Language Sources
