| Application | PLAXIS 2D |
| Version | PLAXIS 2D AE |
| Date created | 20 February 2014 |
| Date modified | 20 February 2014 |
In this movie we will focus on the third program mode of PLAXIS 2D: the Mesh Mode. In this example, we will generate the mesh of an excavation model with a diaphragm wall, a strut and a surface load. How to make the entire mesh finer or coarser will be explained, as well as how to do local refinements.
