| | Product(s): | MicroStation | |
| | Version(s): | CONNECT | |
| | Environment: | N\A | |
| | Area: | Graphics Display | |
| | Subarea: | Display Rules | |
Is there a way to get the Condition Editor to recognize elements that are Selected?
We do not have a criteria in display rules to recognize "Selected" elements.
Display Rules can change element visualization on draw, not modify or select elements
For this you can use Explorer search:
- Select Advance Search
- In Search for: type sphere for example
- Select Where: volume for example
- Change equal for less than
- Type on the box for example: 40 m3
- Select add to search and press ok
- Select again Where: volume
- Change equal for Greater than
- Type on the box for example: 2 m3
- Select add to search and press ok and then you will get this new search in the explorer tool
- Select Elements\ Sphere from Explorer do right click and select Delete elements
See video
www.youtube.com/watch
communities.bentley.com/.../23718.how-to-select-elements-using-a-range-of-values-greater-than-and-less-than-in-order-to-delete-them
Other language sources
Italiano
| | Original Author: | Maria Munoz | |
