| Version(s): | 08.11.09.292 | ||
| Area: | Interchange | ||
| Subarea: | STEP | ||
Error exporting to STEP.
When export any file structural file to STEP
you receive the following error message "Can't find parser database file. Please check the log file"
Product: MicroStation V8i
Version: 08.11.09.292
Area: Interchange, STEP.
This is due to missing certain files from the data\rose\database\ folder.
Option #1. Re-run installation to repair the installation to attempt to
restore the missing files.
Option #2 Copy files from another known good installation from the
folder defined by $(MS_ROSEDB).
