| Version: | V8, V8 2004,V8 XM, V8i ,CONNECT | ||
| Area: | Interchange | ||
| Subarea: | STEP |
How to convert or export a 3D file, e.g. DGN into the STEP format?
The following description is a section of the MicroStation help, which can be found under the topic "To Export STEP Data".
The Export STEP AP203/AP214 File dialog opens.
If you do not perform this step, the filename of the exported STEP file is the same as the DGN file and with the extension ".stp."
If you do not perform this step, the filename of the log file created is the same as the DGN file and with the extension ".log."
The AP203/AP214 Export Settings dialog opens.
The dialog closes after exporting is completed.
STEP Export not complete Missing parts
| Original Author: | Andrew Bell |
