| Application | PLAXIS 3D |
| Version | PLAXIS 3D |
| Date created | 09 May 2011 |
| Date modified | 09 May 2011 |
This movies shows the difference between dragging the selction rectangle from left to right and right to left. Also the sub-menu of the selection tool is explained showing all options.
Due to the continuous development of PLAXIS, the newer versions contain more options to select objects existing in the model. Nevertheless, the main principles of the select tool are those presented in this video.
