| Application | PLAXIS 2D |
| Version | PLAXIS 2D AE.00 |
| Date created | 09 May 2011 |
| Date modified | 09 May 2011 |
To demonstrate the possibilities of Plaxis 2D Plaxflow, we show how to create a time-dependent water head. In Output, we create graphs and an animation. The tutorial lesson Stability of a dam under rapid draw down is followed, see the link below.
