| Application | PLAXIS 2D |
| Version | PLAXIS 2D AE |
| Date created | 20 February 2014 |
| Date modified | 20 February 2014 |
This movie focusses on the Staged Construction mode, the fifth mode of PLAXIS 2D. A tunnel construction is considered here. You will see how to create new construction phases and how to activate and deactivate geometry for the calculation phases to model a staged construction.
