| Version(s): | 10.00.00.25 | ||
| Area: | Configuration | ||
| Subarea: | General | ||
| Original Author: | Leonard Jones | ||
How to export Configuration variable values to a text file?
Command "Show Configuration" now shows the current values of all configuration variables in a text file opened with Notepad
Configuration variables values
Note: This command is also available in the Configuration Variables dialog, File > Show Configuration Values
p>Bentley's Product Support Group requests that you please confine any comments you have on this Wiki entry to this "Comments or Corrections?" section.
For questions or comments unrelated to this article please post a new discussion in this community's forum with a link to this Wiki.
