| Version(s): | 08.11.07.443 | ||
| Area: | Interchange | ||
| Subarea: | STEP | ||
| Original Author: | Nick Rosley, Bentley Technical Support Group | ||
Importing STEP file in MicroStation V8i SS2 and the colors do not display
in DGN file.
In most cases one whole body or part can only have one single color or material. This would also be the case in a MicroStation DGN as one smart solid can only have one assigned color.
