| Application | PLAXIS 2D |
| Version | PLAXIS 2D |
| Date created | 19 February 2015 |
| Date modified | 19 February 2015 |
In this movie we demonstrate the possibilities of the Plaxis 2D Thermal module. Tutorial lesson 16 Freeze pipes in tunnel construction is used as a framework , see the link below.
