| Version: | CONNECT 10.17.02.xx & later | ||
| Area: | Text | ||
| Subarea: | Fields |
The Text Backgrounds for my Text Fields are not turning off. I have toggled OFF the "Use Text Background Color for Field Background" option in the user preferences, but the Text Backgrounds are still visible.
How do I remove the Text Field Backgrounds?
Toggle OFF the Text Field Background View Attribute as shown
This is a new feature beginning with MicroStation CONNECT Edition version 10.17.02.xx & later.
What's New - MicroStation CONNECT Edition Update 17.2 (10.17.02.61)
New in MicroStation CONNECT Edition Update 17.2 – Control Text Field Background color display
| Original Author: | Jayson Perry |
