| Version: | CONNECT | ||
| Area: | Interchange | ||
| Subarea: | General |
Parametric solid does not show up in Navisworks model. However, a simple solid show up in Navisworks model.
Starting from the premise that is currently not possible export DGN to NWD in MicroStation CONNECT Edition (see wiki below), the User may decide to bypass this by importing first the DGN to AutoCAD then to DWF.
This solution may make parametric solids not fully visible in Navisworks.
Exporting to NWD in MicroStation CONNECT Edition
To make 3D elements visible in Navisworks, it is necessary to convert them first to surfaces through the MicroStation Drop Element tool (see wiki below).
How to convert a Feature Solid to a Smart Solid or Surfaced
