| Version: | CONNECT | ||
| Area: | Printing | ||
| Subarea: | Organizer |
When adding Print Definitions to a .pset (Print Set) in Print Organizer, the directory which contains my design files must be manually navigated to each time.
Is there a way to set the default search directory for adding print definitions so time can be saved?
Set the configuration variable MS_DEF in your configuration to point to a specific directory.
This variable controls the search path for design files.
By default, this variable points to C:\Users\<username>\Documents\
but, it can be changed to any directory.
File > Settings > Configuration > Configuration Variables > Primary Search Paths > MS_DEF
For example, you could change the definition to something like this:
MS_DEF = D:/Example/Project/
When setting up MS_DEF in a project configuration, diretory doubled.
Understanding File Locations And Reference Attachments In MicroStation
| Original Author: | Jayson Perry |
