| Version: | 08.11.09.459 | ||
| Area: | Coordinate Systems | ||
| Subarea: | Geographic |
Reproject data from an existing Geographic Coordinate System (GCS) to another
Within your MicroStation session launch the Geographic Coordinate System dialog.
(from the ribbon search (F4) key-in Coordinate System)
Note the existing Geographic Coordinate System assigned to the file. If no initial coordinate system is assigned, no reprojection will occur to the desired coordinate system.
Select the From Library icon
The Select Geographic Coordinate System dialog displays. Browse the library (tab) or use the search (tab) to locate the desired GCS for assignment to the file.
Select the desired coordinate system and select OK
The Geographic Coordinate System Changed dialog will propmpt you with options suited to the current scenario. In this example, a to ask if you are correcting or reprojecting the Geographic Coordinate System (see image).
Choose 'Reproject the data to the new Geographic Coordinate System'
Assigning a Geographic Coordinate System
| Original Author: | Conor King |
