| Version | PLAXIS 2D PLAXIS 3D |
| Date created | 15 April 2012 |
| Date modified | 15 April 2012 |
The general soil test can be used as a customisable soil test mode. The user can define arbitrary stress and strain conditions.
In this example, a drained triaxial test with unloading and reloading is performed using the Hardening Soil (HS) model.
