| Product: | MicroStation |
| Version: | CONNECT |
| Enviroment: | N\A |
| Area: | Printing |
| Subarea: |
Driver/ PDF |
How can I get MicroStation PDF files to be created in the same directory as the design file?
1. Go to: File -> Settings -> Configuration -> Configuration Variables.
2, Search fo the variable: "MS_PLTFILES" and then click: "Edit ....".
3. Change the value to: "$(noext(_DGNFILE))".
4. Click: "OK".
5. Close and open Microstation again.
Printing Configuration Variables
