| Application | PLAXIS 3D |
| Version | PLAXIS 3D 2012 |
| Date created | 20 November 2012 |
| Date modified | 20 November 2012 |
In PLAXIS, all connections between structural elements like plates and beams are created rigid by default. Since PLAXIS 3D 2012, it is possible to apply custom connections with one or more degrees of freedom for rotations and/or translations.
