| | Product(s): | MicroStation | |
| | Version(s): | 10.00.00.25 | |
| | Environment: | N\A | |
| | Area: | Printing | |
| | Subarea: | Organizer | |
In MicroStation CONNECT, I want to use Print Organizer via a single Key-in to generate a multi-page PDF, from the multiple design models I have in the design model I’m currently viewing. How can I do this?
I will assume you are using a delivered copy of pdf.pltcfg and that you have a print style that describes your plot area and sets the print as you want.
Next create a text file (printset.txt) that contains the following Key-in commands:
mdl load bentley.printorganizer.dll
PRINTORGANIZER NEW
PRINTORGANIZER PRINTERDRIVER pdf.pltcfg
PRINTORGANIZER ADD ACTIVEFILE Multiple_Shapes
PRINTORGANIZER SUBMITAS SINGLE
PRINTORGANIZER PRINTDESTINATION $(MS_PLTFILES)$(basename(_DGNFILE)).pdf
PRINTORGANIZER PRINT ALL
PRINTORGANIZER DELETE ALL
PRINTORGANIZER EXIT
The scripts loads Print Organizer, sets printer driver to pdf.pltcfg, adds the active file and calls “Multiple_Shapes” print style, sets print to a single .pdf file, sets the destination according to the variable MS_PLTFILES and names the output file to the design file name, prints, deletes the contents of the .pset and dismisses the Print Organizer interface.
In the Key-in window, type in the following:
@printset.txt
Note, you may have to give the path to the script file.
A description of each key-in command can be obtain by launching MicroStation Help, expand “Working with Completed Designs”, Expand “Printing”, expand “Using Print Organizer” and “Print Organizer key-ins”.
Tutorial: Automating Printing through Print Styles
