| Product: | MicroStation | |||
| Version: | V8i, CONNECT | |||
| Environment: | N\A | |||
| Area: | Printing | |||
| Subarea: |
How to print a PDF file with levels and files content.
For printing to PDF with optional content in levels and files in the PDF file
Make the following changes to the printer driver configuration file PDF.PLTCFG (Best practice: save it under a different name):
In the Print Dialog:
| Original Author: | Evert De Jong |
