| Version: | CONNECT | ||
| Area: | Configuration | ||
| Subarea: | Workspaces |
(Example): _USTN_CUSTOM_CONFIGURATION= E:\My Company\Configuration\
You can do these same steps within Bentley View to load your MicroStation CONNECT resources in Bentley View for your files to display properly in that product as well.
For Bentley View CONNECT to load MicroStation Workspaces
Browse to Bentley View CONNECT Edition
C:\ProgramData\Bentley\Bentley View CONNECT Edition\Configuration
Open ConfigurationSetup.cfg using Notepad or Note Pad ++
The variable is already there, add the Local or Network path to MicroStation CONNECT configuration location:
(Example Local Path):
_USTN_CUSTOM_CONFIGURATION= C:\ProgramData\Bentley\MicroStation CONNECT Edition\Configuration\
(Example Network Path):
This will load whichever one you point to.
Note:
When you start the Product and get to File Open Screen, the Workspace pull down should have all the workspaces listed there to choose from.
Note:
If you are upgrading from a previous update of MicroStation CONNECT Edition and have Custom Configuration set, you will have to select the same in the Custom Configuration field of the Configuration page.
| Original Author: | Todd Moser |
