| Version: | 10.17.02.061 | ||
| Area: | Configuration | ||
| Subarea: | Workspaces |
Users get the following message when opening MicroStation Connect Edition
IT created image that did not have Write access to the following files.
Write access was provided to the following files to fix the issue.
C:\ProgramData\Bentley\MicroStation CONNECT Edition\Configuration\ConfigurationSetup.cfg
%localappdata%\Bentley\MicroStation\10.0.0\prefs\cache.ucf
MicroStation Connect Edition requires Read/Write access to the following folders.
%temp%\Bentley\MicroStation\10.0.0\
C:\Program Files\Bentley\
C:\Users\{UserName}\AppData\Local\Bentley\
C:\Users\{UserName}\AppData\Local\Temp\Bentley\
| Original Author: | Leonard Jones |
