| Application | PLAXIS 2D |
| Version | PLAXIS 2D |
| Date created | 13 June 2013 |
| Date modified | 13 June 2013 |
With the Parameter Optimisation function in PLAXIS SoilTest, it is possible to optimise estimated soil parameters towards real lab test results.
During this video, we will work with an estimated HS dataset of a sand/gravel. We will optimise the strength (φ) and the stiffness (E50ref). We will use the results of several real triaxial lab tests for the optimisation.
