| Version(s): | 10.17.01.62 | ||
| Area: | Properties | ||
| Subarea: | Reports |
Report on Items in Reference File
Request from User:
I want to produce a Report of Items contained in a Reference File
This can be achieved through Reports feature in MicroStation Connect.
• Select Report Definition and under Properties, Set Include Reference Attachment to Yes
• Select the required Objects to report on
• On the Right select Item resides in Reference
• In the drop-down list select, Reference contains Element
• Further selecting Elements
• Preview report results
Blog: Reporting on MicroStation V8i DGN data in the MicroStation CONNECT Edition
